Chris_feldk
- Aug 19, 2023
- 32
I did an engine swap on my cub cadet, a bought a cv16s at the time of buying I didnt know that It had an unregulated 3 amp charging coil unlike the 15 amp cv16. I needed a 15 amp so I bought a cv16 flywheel and cv16 stator. I bought a used flywheel but an Amazon stator and regulator. Everything bolted up good and I get 35 volts off of one ac wire but 3 off of the other, and when connected to the regulator I get 3 volts. I get 0.3 ohms through the stator and the wires aren’t shorting to ground. Do you guys think it’s the cheap stator? Any help would be great thanks
