If you can tie boot laces ya can replace the bearings . There's only 3 pieces inside the assembly and all will go in either end first .YELP! When you get to changing the bearings out separately, that's beyond my pay grade>>>>>may need to
go off on a week long bearing seminar to do that
Put your own grease fittings in before installing, I so this on alot of greaseless ones. Also notice that ones with grease fittings have rubber sealed bearings so whats the point? I usually cut a small slit in rubber seal so grease can get in on the inside. Been working for years.I've had this riding mower since 2019 and after this much use I'm anticipating replacing them even
though at this point they seem to be doing ok. From past experiences I never get more than five years
out of a Mandrel assembly. So on my last sears mower I replaced those mandrels with ones that had
grease fittings which worked real well. But---now I see from doing internet searches, all the mandrel
assemblies available for my mower are grease-less?
Could somebody please explain how these new mandrels work without grease? and is it a waste to
look for an assembly with grease fittings these days? Thanks Bob
Couple of thoughts: Somewhere in Timken literature, the term used was "shield." This makes more sense than "seal" when grease/water/dirt can get around whatever is covering the bearing retainer.
I read Bert's post #7, just above, as the ZZ actually is a sealed bearing, as in nothing gets in or out ... ergo sealed.
However, we all just read Star Tech, post #6: "The bearings has to be change to ZZ bearings from the the 2RS bearings as the ZZ will allow grease to enter and exit the bearings while still retaining most of the grease." I read that as not "sealed."
123Bearing Co. calls the ZZs: "... 2 sheet metal deflectors, for dust-tightness. ..."
Are there no actually grease and water tight bearings available? ZZs cost more but is the difference meaningful?
A "RS" or "2RS" suffix is a rubber sealed bearing.The "2RS" is sealed on both sides.A "RS" is sealed on one side only..A shielded bearing,like with a "KD",or"KDD" bearing is a shielded bearing,It is designed to keep dirt out,but not keep grease in.A Sealed bearing does both.What happens when you try to force grease into the sealed bearing is a lot of the time the inner seals are pushed into the bearing and the outer seal can actually get pushed out. The bearings has to be change to ZZ bearings from the the 2RS bearings as the ZZ will allow grease to enter and exit the bearings while still retaining most of the grease.
Also both the greaseable and non-grease spindle are the same retail price and cost.
I also see no reason to change the spindle housing when just the bearing are needing replacing; unless, you try removing the spindles to change out the bearing which leads to broken mounting screws.
You are removing deck, change the bearings without removing spindles the from deck. If you put on a bench it's an easy job.OK Thanks, I might just try doing the bearing change out when the time comes and use this thread as a
reference. Other question I have is from past experience in removing the mounting bolts that hold the Mandrel
assembly in place usually break off when you try to remove them! For the normal hack mechanic
like me, that pretty much renderers the housings un-useable
I guess pre-treating the treads with penetrating oil might help that
