Cub Cadet EZ oil drain pull & twist
Rickcin
All will work. Black pipe is normally for Natural Gas or Propane. Galvanized more for water and stainless for caustic materials. But since there is no pressure all are find. I normally use black pipe.
Thanks again, I really appreciate your advice😎
Rickcin
Now I’m wondering if I could add a ball valve for easy draining and if I could use this with galvanized pipe?
As long as it doesn't leak and doesn't get bumped to the open position while the engine is running.
Rickcin
I was going to cap it for added protection.
I replaced that cheap plastic easy drain that came standard on my Cub Cadet XT2 lawn tractor. The day after I changed the oil and filter, there was a puddle of oil on the shed floor from that plastic drain valve.
I now have it piped with 3/8 inch stainless with a good quality ball valve and I have the handle locked in place with a strong zip tie.IMG_1766.jpegIMG_1767.jpeg
driz
I am pretty sure you can take that nut off the lever and reorient it so it’s straight up when closed. I did something similar with an identical valve to keep from smacking into the shutoff for my outside garden faucet.
Rickcin
You are probably correct, I would have to be very careful when doing that though.
Rickcin
I took a closer look at the photo of the valve and the handle cannot be positioned
After an enlarged view of the photo of the valve, you can see a nub on the valve body and the handle will only work in that one position.
I could just remove the handle but Im thinking it’s fine as is and will not be a problem.
Another option was
or
Probably still would need to loosen the engine to install either one but they are better than the plastic one.
