Piros1
I think you have had enough answers regarding cutting your grass, you let it get to long, etc so I’m not going there. Also as stated you could install a much larger engine to do the job but your deck won’t handle it. I think all this is covered. But you asked about more CC’s. CC’s is metric and stands for cubic centimeters kind of like CI (cubic inches) in US terms. The more CC’s your engine is the larger the displacement kind of like a Chevy 327 compared to a 427. So in theory everything being equal a 170 CC engine should have more power than a 140 as would 220 CC have more power than a 170. The issue becomes mounting the engine to your deck and the length of the shaft protruding through your deck and will your blade and hardware mount to the larger engine. By the time you are done you may be money ahead to find a good used mower to your liking. It is doable provided your hardware and the engine are a match up. I don’t think it will solve your issue with your existing mower and conditions. The deck design of any mower has a lot to do with how the grass is discharging out the shoot. I do think that if you are planning to swap your 140CC engine for a 170CC engine you will notice lift or no difference and I feel personally you would be wasting your time and money.
I wish you the best and good luck on your decision.
