Skippydiesel
No High octane fuels, will not cause "knocking" in small engines.The burn rate difference between 87 and 92 is negligible in stock small engines. We are not doing max HP pulls on a dyno.
Has anyone seen a small engine damaged from preignition?
They will have little if any effect, good or bad however your expenditure will increase for no benefit.
