Engine What kind of oil ?
pshome
I've just sold something and came into a bit of money, so decided to buy the proper 10W30 oil my mower asks for, as I'm currently using 10W40.
Anyway, does it have to be lawn mower oil, or will regular 10W30 car oil work fine ?
Lawn mowers have air cooled engines and as such they operate at higher temperatures than car engines, which are generally liquid cooled. Therefore, the oil requirement is also different and calls for single weight oil such as 30W. The car engines specify multi weight and viscosity oil, such as 10W40, which have many additives and viscosity enhancers, which tend to deteriorate at higher temperatures as in a air cooled engine, degrading the oil for high temperature application.
sallymander
10w30 is the lighter oil and would be better for colder climates.
Big problem you can run into with 10w40 oil is most of it is made for diesel engines and has different properties than gasser engine oil.
You would have to look at the label well before buying to make sure it's for a gass engine.
Amsoilman1
Hey all Amsoilman here. I have weighed in on many of WHAT OIL questions. Please Take whatever lubrication you use and get their comparisons to Amsoil Products. In most cases the company you use WILL NOT have anything. We at Amsoil test against any and all lubricants that is worth while testing with. Please do so. If you want you can check yourself with "Amsoil" at AMSOIL - Synthetic Oil, Motor and Engine Oil, Lubricants, Air Filters, Oil Filters and Greases ... If you have any more questions I can help answer pertaining to lubrication please donot hesitate to ask. Thank you for reading my response.
Oh yes MOST air cooled engines can use Amsoil ASE small engine oil. The member stated that their isnt any difference in auto and small air cooled engines is sadly mistaken. Please read and better informed. Thanks again.: Amsoilman
jmurray01
, , 1,000 Post Club
Just to put an end to this thread - I ended up buying some SAE-30 (Straight-30) oil specifically for my type of engine.
Carscw
If you sit 10 guys at a table and ask about what oil to use your going to get 20 opinions Then ask them a week later and you will get 20 more
Sent from my iPhone using LMF
jamesslcx
jmurray01, this is now an eternal thread, we will never know the true answer until we make a virgin sacrifice to the oil gods, virgin oil that is!:confused2::laughing:
Amsoilman1
Another misinformed individual . Please read annd donot put any processed dirt in your valuable ehgines.
Thanks again: Amsoilman
fenderbender
The part I don't understand is why would you want 10W30 over 10W40. Do you mow grass in Scotland when it is real cold and need the lighter oil? The 10 is when the mower is first started and the oil is cold and the high number 30 and 40 after everything is up to operating temperature.
Oil does not get thin when it is cold and thicker when it is hot!! It just doesn't get thinner than standard 10 weight when it's hot, nor thicker than standard 30 weight when cold. Pour a bottle of 30 weight and a bottle of 10-30 when they are cold and you will see what I mean.
Black Bart
fenderbender; You have it Backasswards,
KennyV
Multi viscosity oil has been around for Many decades, for longer than some here have been alive ... and still there are those that do not know what it is or how it works.
Same for synthetics and additives why they are there and what they do... and now added to the misinformation regarding those add that there is someone now implying that diesel rated oil is somehow inferior to gasoline oil...?
I don't know if some just don't care enough to find out facts about better oils or if it is they have some partial remembered misinformation ... but it is amazing how much opposite information gets posted everywhere... I sure hope that those, that are unsure do a bit more reading than just skimming the nonsense that gets perpetuated... Use the resources that are available, this information is available World Wide... There are no lubrication 'secrets' anymore... it's 2012 not 1952... but still there is too many completely wrong statements made about oils..
You will never find a better oil for an air cooled engine than a Diesel rated, multi-viscosity synthetic... You can subtract any of those 3 things... each time you do you will have a Lesser lubricant...
:smile:KennyV
