johndeere 285, 18hp twin, 1990 model
44ron
before warming, runs on one cylinder, I open throttle to normal mowing speed during this time, after 10 minutes or so the non-fireing cylinder kicks in and it usually runs fine till I finsh mowing.
The first thing I would try is a new spark plug. It has to be something that once it gets warm it starts to fire. It should be a easy find seeing it misses when it's cold. Just do all your diagnosing when its cold, I would start with spark, compression, fuel, and then timing.
Hummmmm.First I would check dead side with a new plug in plug wire for firing.If it's not firing,check that coil and wiring to that coil.Check air gap too.If that plug is firing...hummmmm.....intake issues?
