peteclark3
Ok, thanks. First, I'm going to get a new digital multimeter at home depot, because I feel like I can't get a consistent reading with what I have. Very hard to follow the needle.
Do you have any idea what the resistance should be (the reading on the multmeter.. roughly?) when the points are open/closed?
Also, should I have NO continuity between the points when they are open? Or still some continuity, just with more resistance? I ask because what I'm struggling with when trying to use the multimeter is figuring out why there shouldn't be continuity when I touch the black to the ground and the red to the side of the points that opens, when the points are open. It seems that everything in there is metal, and everything seems to touch everything else at some point, why wouldn't there be continuity?
Thanks again. :-(
Thanks again. :-(
