LeGear1!
My lawnmower is very slow in moving when first started. It takes a while of working the controls for it to move like it should. I have removed the old fluid, filter, strainer, and used compressed air to remove all the old fluid from the system. It worked better for a short time but with the temperature dropping it is worse than before. I used all specified Grasshopper parts. Has anyone had the same problem that could give me some info on what I need to do next?
Thanks for any help,
WL McCabe
WL McCabe
