Plastic Replacement Fuel Tank for B&S XR950/Model 130000?
DC712001
  • / Plastic Replacement Fuel Tank for B&S XR950/Model 130000?
The Metal Fuel Tank on my B&S 9.5 Lb/Ft torque XR950 Model 130000 engine is rusty and fouls the fuel system/carb. It is mounted on a DR Chipper purchased in 2017.
I had cleaned it out removing all rust and mounted a New in-tank filter, but I’m sure it is rusty again.
I bought a can of fuel tank costing, but never got around to recleaning the original tank and applying the coating.
I noticed that there are Plastic replacement tanks, but I don’t know the correct P/N to order.
I “believe”IMG_8060.jpeg the current Metal tank is P/N: 592877.
Does anyone know the correct Plastic replacement tank P/N?
Thank You
There is no replacement that I know of due OSHA regs. This engine was design for go cart use which require only metal tanks for safety purposes.
DC712001
Thank You for the reply. Hmmm… this engine is on a Chipper/Shreader.
Thanks again.
DC
The actual model type and code from the engine would really help us to identify what is available.
DC712001
It is a B&S XR950 Professional,
Serial No.: 16-0624-98-69674
purchased in 2017
So it is an 130G32-0127-F1 Some of the older single cylinder horizontal intek engines had plastic fuel tanks, but the XR. CR series are kinda a Honda clone which uses metal fuel tanks.
DC712001
Thank You.
Could one of the earlier plastic fuel tanks bolt on?
DC
DC712001
Good to know.
Thanks
DC712001
Could something like this work or be adapted?
