Scag scz61v-34kh hard to crank
I have heard of the issue and was discussed at a Kohler update a few years back, but like you said no real solutions were given. Some of the Briggs big block Vanguards have a similar issue with kickback when trying to restart while hot.
Where did you typically attend Kohler updates? Effingham?
Yes it did, it will crank over the same with plug wires attached without the choke on. I have a fully charged battery & installed a new starter also. I'm baffled by this.
