Sounds like one of the old 50's era Evinrude dual hose system that used air from the engine to pressurize the fuel tank. Haven't seen one of those for a few years.We had a fishing boat ( small one ) with an outboard and a sealed fuel tank so every now & then you had to pump it up
If you use a mower often enough, there is no need to be concerned about condensation.The gas cap is believed by some that even when screwed on tight, still allows for condensation to enter.
There is an article on IFishFishing Forum, & I'll quote from it:
There isn't enough air volume within a tank to hold much vapor.
On average, tanks are half full, further reducing volume
The amount of water vapor in air is very small, even at 100% humidity
Conditions aren't right to cause condensation in a fuel tank.
_________________________________________________________________
This makes the most sense to me. how can condensation (moisture) penetrate through a tightened on gas cap?? Please, if you have some logical rebuttal to this, then post it.
Assuming, I'm wrong & IFishFishing author are wrong, the same posters who believe gas caps don't keep moisture out recommend to take a piece of plastic wrap & place it over where you will tighten the gas cap. However, at least in Craftsman mowers & I would think other mowers have the same design, it DOES NOT WORK because there is a string coming out the bottom of the gas cap, and at the other end of that string is a U-shaped large piece that hangs in the tank, & you have to turn it sideways to get it out of the tank. End result is you are holding a gas cap with a string. I don't understand its purpose other than it is a way of telling you, if the U-shaped piece is not completely submerged in gas, that you need to add fuel. This whole design is IMO ridiculous. Just have a gas cap without this extra nonsense of strings & U-shaped pieces. If the user can't use a flashlight to look in the tank & see the level, then they should hire a lawn service.
So, NO plastic wrap for me. A friend of mine suggested just placing the plastic wrap (or better a zip lock bag) over the hole & use rubber bands to keep it on and seal any outside condensation from entering. IMO, this is just too much of a hassle. If you want to take this to extremes, take a good size piece of plastic wrap. Place it over the entire tightened gas cap, & use an appropriately sized rubber band to seal it to the top of the gas tank's tube.
If you disagree, please post with something other than just stating that gas caps are not airtight & allow moisture through. You should read the article, "THE MYTH OF CONDENSATION IN FUEL TANKS"
The Myth of Condensation in Fuel Tanks
www.ifish.net
A couple weeks ago I started a snowblower that had been sitting in my garage for 6 years. I ran it for 5 minutes without any problems. People get all **** about the fuel worrying about if the cap has a good seal, draining the tanks dry, putting fuel stabilizer in the tanks, ect, ect. Unless you are purchasing 100% gasoline, then it already has 10% alcohol in it and the water will be burned when it is running.Looks like another great internet debate. Just me, I store my zero turn completely full. Everthing else is empty and run dry. Never have a water problem. Probably a quarter of everything customers bring in have some water in the tank. I dump every handheld, push mower, tiller and snowblower that comes in. I see lots of water.
I have never had a problem with water in the fuel. I have some methanol left over from drag racing. That should take care of any water.Yes water can get in tank with fuel caps as they do vent inwards. And some do go bad too. Just had a tiller earlier that I put on a new carburetor with new fuel lines and new fuel. It came back a month later with water damage to the new carburetor. I found a bad fuel cap allowing rain water to enter via the vent hole.
And with ethanol fuels water vapor will combine with the fuel and then settle out as water. Small amounts at first until it builds up over time. Most is not noticeable as we are normally using our during the mowing season. It when they sit for extend periods that this settled out water seeks the lowest point which with gravity fed carbs is the carbs itself. Once there corrosion happens.
Besides most water get introduce from poorly sealed containers just like grass and other trash in fuel does. I rarely find in my eqiupment unless I get bad fuel from the local station which is why I quit them. There tanks has caps on them too but had a bad one that finally got replaced.
the myth? lol....with years of proof that this is no myth you are going to expect anyone to accept that water ingress into fuel tanks is not a thing?The gas cap is believed by some that even when screwed on tight, still allows for condensation to enter.
www.ifish.net
Air contains Moisture. A Fuel Tank MUST be vented to allow fuel to flow out, thus fresh air is being constantly drawn into the tank. Covering the fill neck with plastic will help with that if it is a tank not being used for an engine. To store Fuel, fill the tank to the Top and keep in a cool dry place. Try to use it within 30 days and refresh tank. Ethanol absorbs Moisture. That is the big problem.The gas cap is believed by some that even when screwed on tight, still allows for condensation to enter.
www.ifish.net
Be careful with the Methanol. It can seize plastic shutoff valves etc.I have never had a problem with water in the fuel. I have some methanol left over from drag racing. That should take care of any water.
