reynoldston
- May 23, 2011
- 5,705
Just why is everyone against using a puller to remove a flywheel? I have removed many flywheels and never damaged one yet using a puller. Just what am I doing wrong? I have seen more damage to the top of the crankshaft from someone hitting it with a hammer then any puller has made. Is a puller too much work or too slow? Just what damage is the puller doing? In a earler post somesaid a 8 lb hammer. Is that better?? Am I wrong in saying a 2 cycle uses roller bearings on its crankshaft and just what does all the hammering doing to them bearings? Or am I wrong in saying it is bad to hammer on a roller bearing. You are sure not working on anything of mine.
