professor229
Need some advice. Was looking for a small push trim mower for my yard, and traded some car parts for a Yard King self propelled push mower. It is an older mower but starts every time on the first pull and has been a good mower. It is time to put it away for the winter so yesterday I decided to change oil on it and clean it up real good. I sharpened the blade and then went about the oil change.... and looked and looked and looked... There was no obvious drain plug... Is this one of those "tip it over to drain the oil" mowers???? I tried to do that... and no oil came out for some reason... and yes, the dipstick shows there is oil in the machine... so that is a head scratcher too.... Anybody own a Yard King push mower and know the answers to this???? PS.... I just added a little more oil to it and put it away for the winter. It is NOT a big deal because it is an older mower and I don't use it all that much...... Help/suggestions/advice appreciated.... and PS... I did try to look for a manual online and found a user manual for it that shows how to check the oil, but it does not say anything about how to change the oil on it..... Thanks...
