Where does this wire go?
LarryJohnson
Been trying to get a B&S started. Found this loose yellow wire under the seat but don't see another end to plug it in. I can't figure out anything from looking at the wiring diagram.
Also, where's the fuse hidden on a murray
Untitled by Larry Johnson, on Flickr
Poke your head into the battery hole
If the solenoid is on the back panel then the fuse will be next to it
If the solenoid is on the floor under the dash then the fuse will be there next to it .
The yellow wire will go to the reverse cut out switch if it is a hydro or the neutral switch if it is a manual box
My lord..Rivets links the wiring diagram provide the OP dropped a Zero from the model number which he made jump through hoops to find it.
But someone disconnected the seat switch and the connection goes back to the PTO switch. But here is the electrical diagram.
I’m tired of trying to make it easy, especially when I have to look for numbers or incomplete numbers. I will help those who do that, but expect them to do a little work also. We’ve learned the hard way, they should also. When you do it the hard way, makes it harder to forget.
