reynoldston
Seeing that it runs a few seconds you have everything to make it run. ( compression, spark, timing,) It sound like it is getting enough fuel to keep running. You say it is getting a good flow of fuel to the carburetor. I sure don't know what changing the oil has to do with it not ruining. It just seem in my years of working on mowers I ran across a Kohler that had a low oil level cut off switch once. So for some reason the fuel isn't going through the carburetor and that was the reason I asked about the carburetor solenoid. The next thing I would do is pull the carburetor off and check the float and needle valve and any dirt in the carburetor.
