smallenginerepairs
I'm working on a cub cadet zero turn with a 25hp kholer twin engine. When i engage deck the mower loses power. I checked the coils, and one was not firing. I bought an after market coil, put it on the engine and hooked up the kill wore that goes from the key swotch to both coils. One coil cuts out.If I take one kill wire off the both fire. The kill wore runs from one coil to the other coil. Same wire. It dosen't matter which kill wire is taken off, both coils work if one kill wire is removed. What is happening?
