VegetiveSteam
- Jun 1, 2022
- Threads
- 2
- 467
No. That's the voltage regulator.
This is a SAM
View attachment 66677and this would cause one cylinder to run hotter ?
Well I'm not sure where to go now with the backfiring. Coils been replaced carb cleaned new spark plugs ran sea foam through systemIt shouldn't no.
Look at post #10 of this discussion in the link below. Watch the video. It will show how to find valve overlap. If overlap occurs any place other than the piston being at top dead center at the end of the exhaust stroke your cam and crank are out of time with each other and that could cause backfiring. Just remember the four cycles or strokes. Intake, Compression, Power, Exhaust. What comes after exhaust? Intake. So with the piston at top dead center between the exhaust stroke and the intake stroke both valves should be open just a little bit. At top dead center on the compression stroke, both valves as you probably know should be closedWell I'm not sure where to go now with the backfiring. Coils been replaced carb cleaned new spark plugs ran sea foam through system
You can check it on either cylinder on your engine. You will need to take the spark plugs out and turn the engine over by hand in the normal direction of rotation which is clockwise looking from the flywheel side of the engine. Use something like a wood dowel to slide into the spark plug hole to feel where the piston is. Make sure the dowel is ong enough not to slide into the hole. You can use a screw driver if you're gentle and don't bang it around on the top of the piston. You're just trying to feel where the piston is.
Kohler xt675-2047 NO MARK crankshaft
Hi everyone, I have a problem because when I was removing the oil pan, the camshaft in the Kohler xt675-2047 engine from the Viking lawn mower popped out. The worst thing about it all is that there is no mark on the gear that is mounted on the crankshaft (it is fixed in place, it is not...www.lawnmowerforum.com
