Folks, I'm curious what voltage you prefer in battery weed wackers?  Currently I have a 40v brushless Ryobi MD #
(RY40270VNM) that I feel does a good job. thanks  Ray
Voltage is almost irrelevant. Manufacturers use voltage to coax consumers into paying more. "Bigger numbers must be better! Right? After all the higher voltage tools cost more!"
The higher voltage tools cost more because manufacturers decided to make more expensive tools, and use higher voltage because they know consumers will assume the higher the better.
DeWalt is mostly sticking by 20V but has surrendered with a dual 60V/20V battery and tools.
EGo sticks with 56V for everything. No "premium" higher voltage tools.
The higher the voltage the more cells must be used. The more cells used the smaller they must be. All the while the 18650 cell is the biggest bang for the buck to be had. That I know of, DeWalt and EGo use 18650 cells.
