Hammermechanicman
- Jan 10, 2020
- Threads
- 68
- 3,875
I have a 361 clone and a 660 clone both running 195psi compression. If you don't use the compression release it breaks the starter pawls. Over 10:1 compression ratio. Dozens of tanks of regular gas through both.
I have always wondered what the failure mode of 2 strokes is when a fuel with too low an octane rating is used.
