As the first responder you were told in the first response that the gauge wheels have nothing to do with the deck height or level
So I will repeat what what was written
The deck hangs of the mower
The wheels should not be in contact with the ground in normal mowing
They are there to prevent the blades witting the ground when you run over a bump or make a turn
They have nothing , nada , nill to do with the leveling of the deck
IS this clear now ?
The deck is leveled left right using the height adjusters on the hangers that hold the deck
On a good quality mower there will be one at each side usually on the rear hangers
Then the deck is leveled front to back using the front drag link
As for the forum server , yes it has a file size limit because disc space costs money
Most computer users have no idea about file formats & sizes
The server does not display PD file , just provides a down load link
I generally post text pages as a JPG so they display in the post
If you are posting using your phone then the server will see the file as being many times larger than it actually is because of the way phones save data
I have told people thousands of times that a phone is not a computer but they never seem to get it
Normally I would level the deck with the blades dead across the deck left right then do the front back with the blades directly ahead
Because the blades are aligned with the left in front of the right a properly leveled deck will have the left side of the left blade slightly lower than the right tip of the right blade when the deck has the correct attack angle ( slightly lower at the front )
Now because Craftsman's are now a house brand and build down to an even lower ticket price than they were when Sears owned the brand they have probably done the MTD cheap & Nasty trick of only putting one adjuster on the right rear deck hanger so they are trying to get you to set the deck level in one step by measuring the blades diagonally
IS this clear now ?
