MurphreeJon
- Aug 17, 2023
- 3
Started doing this a few weeks ago. On start it will act like the battery is weak.. first turn over will sound normal for a few moments but then stop before it's gone long enough to fire the engine.. after that it will make an occasional turn but not enough to fire. I was able to start a few times with starting fluid assistance. Naturally I blamed the battery and ran out ot get a new one... same issue.. just noticed too (with the seat up) that the ground wire going to the battery seems to get pretty hot while trying to start (smoking hot). Does this sound like a failed starter or should I look elsewhere. (I've visually inspected all the wires I can find and everything appears snug) I've got just over 90 hours on the mower. Thanks
