Which oil ?
beretta22
ZTX5 ZT740 Kohler. Changing break in oil in about 2 hrs of break in time left. Thoughts on which oil to use ?
shurguywutt
10w30 if you mow where it gets cold. If you live in the south (100*+ right now) I run SAE 30 all day.
I have a KT725.
Born2Mow
► Choice of engine oil is based on the ambient temperature in the area, with considerations for your cooling system type.
• It's been in the 90°F+ range for the last 8 weeks here in Georgia, so I'm running 15W50 in my well broken-in, air-cooled V-twin mower. I'll go back to 10W30 when cooler autumn temps get here.
• If my mower was water-cooled, then the operating range of the oil would be controlled by the radiator's thermostat, not the heated air. So I'd be using 10W30 all year round.
TonyPrin
IMO, you can't go wrong with 10W-30 full synthetic which is fine at just about any temperature.
MParr
Kohler 10W30 is a very robust oil and is formulated for small engines. They contain nearly twice the zinc and phosphorus content of passenger car oils.
Scrubcadet10
Moderator
Staff member
Kohler and Kawasaki KTECH are all i use for 4 cycle air cooled
