Hi, I recently purchased a 2012 Husqvarna RZ4824F with the Kawasaki FR730V-AS13-R on it. My friend was starting it by jumping the solenoid with a screwdriver. He told me all it needed was a new key switch. I replaced the key switch and nothing. I started checking the wiring harness and noticed some things were unplugged or disconnected. When i checked the only wiring diagram I could find there was a wire going to the solenoid that i didn't recognize. It's a black wire with a small white stripe on it. No idea where it goes. And I found a solid black wire in another part of the harness that looks like a ground and the diagram said connect that to the engine block. I would really appreciate any help with this, Thanks.
