reynoldston
I really don't see how you would of bent a tie rod. The reason I say that is they are back of the axle and high. It looks like they would be well protected from hitting something. But for sure check them who knows. Frist thing I would do is jack the front wheels off the ground and rock the wheels back and forth and see if the king pin bushings are worn? If not worn take some measurements from the end of the spindle ears to the wheels.
