Only if it’s primed
Old fiddler
Yes, spark is good
I changed the mag thinking that although there was spark, maybe it was too weak to fire it
Fuel lines are part of the base of the carb - both have fine screens on the bottom (both clean)
Both the old carb that I cleaned, then rebuilt, and the new carb, which is not an OEM, act the same way
Old fiddler
Yes, spark is good
I measured the length of both pickup tubes to make sure they were not sitting flat on the bottom of the tank, and added an additional gasket to give a few thousands more.
Craftsman Garage
the setting for the mixture screw is turn in until snug, and then back out 1 and a 1/4 to 1 and a 1/2
