This is the Ruixing carb used on engines built after 2016 with a fuel pump.
Find genuine OEM replacement parts and diagrams for the Air Cleaner, Blower Housing, Carburetor - Ruixing, Kit-Carburetor Overhaul - Ruixing for the Briggs & Stratton 31P677-0123-B1 - Briggs & Stratton Vertical Engine
www.partstree.com
This is the Nikki carb used on engines built before 2016 for gravity feed engines.
Find genuine OEM replacement parts and diagrams for the Carburetor - Nikki, Fuel Supply, Kit-Carburetor Overhaul - Nikki for the Briggs & Stratton 31P677-0123-B1 - Briggs & Stratton Vertical Engine
www.partstree.com
i know that is says the Nikki carb supersedes to the Ruixing carb, but my experience has shown me that they don’t often work like the engineers say they will. Pressure on the float needle is different, higher with a fuel pump, lower with gravity feed. Sounds like this may be your problem, but make sure you read my signature.
