Sounds like you are looking for swing back blades like these.
And personally I would use them in swing mode and forget keeping the rigid position. My 4 foot rotary has work very well over years.
As Bert said these are probably agriculture blades. And you may need to use bushings as even the ones in the image above have 0.83 holes based on them being 2-1/2 wide / 3.
