B&S Inteck 18hp single cyl hunts seems to run OK for 10 -15 minutes then aggressively hunts .
New Gas, tank clean
New carb and filter
New Plug
Checked gas cap for venting (OK)
set governor and replaced spring (set Static adj) Ides fine max rpm sounds OK
Happens when I use the tractor for lawn fertilizing with a trailer tank (small) and sometimes mowing
If I engage the blades RPM's seen to level out momentarily when spraying
Thanks
Freezzman
			New Gas, tank clean
New carb and filter
New Plug
Thanks
Freezzman
