Diesel_Dude08
Hello, I have a John Deere 14SE push mower with a Kawasaki FC150V. I got it a few years ago but havent had too much time to mess with it. it used to start and run, but it would SCREAM at like 20,000 RPM it seemed. A few months ago I did a static governor adjustment and adjusted the throttle cables and made sure the butterfly and everything opened and closed as far as it should. I started the mower and it didn't scream, it ran pretty low RPM. I would go to throttle it up or down and the throttle plate would move, but it wouldn't actually move the governor arm. It would run constant rpm no matter where I moved the throttle lever. Adjusting the High idle screw did nothing. The only time it would throtle down is when it got to basically idle. However, if I would bump the governor manually with my finger it would rev up then slow down more. Today I finally pulled the sump off to look at the governor and it was not destroyed and seemed to be working properly. I went to put the crankcase cover back on and I snapped one of the bolts.... of course. I have a video of what it was doing after I adjusted it, but unfortunatley I can not insert it below. If anyone has any ideas and could help me out, I would greatly appreciate it. Thanks for your time!
-Cody
-Cody
