StackAttack
I have a Ryobi RM300e electric rider and when I got it out to mow this past weekend it acts like it has a low/bad battery. It will drive forward or backward for about 3 feet then kinda die off and beep 5 times. Acts like the battery is low although it was on charger and should be full. When I test the charging port with a multimeter I am getting 54v but the battery LED gauge (under the key port) is showing only about a 20% charge. I'm wondering next steps to test batteries further to ensure they are in fact good (maybe weak under load?) and/or diagnose further to see what the issue is....
Help?!
Help?!
