ncb1038
- May 27, 2023
- 5
hello everyone i have a cub cadet rzt 50 with a briggs and stratton engine on it. The model for the machine is 17ba5a7p709.
the big issue i have so far is its hard to sstart, if i am able to get it running it may run up to about half to three quarter throttle before bogging out.
a little back story.
so far i have overhauled all the basic tune up items i can think of. The unit has new fuel lines and air filter. A new carburetor (old one was severely gunked up) all gaskets have been swapped during carburetor changeout. new plugs new air filter and oil is bew as is filter for oil. Gas has been drained from tank and has fresh gas only 2 to 3 days old.
battery is good and holding a charge with no issues. Although i have had to trickle charge it a few times due to struggling to get functional operations out of the machine.
Things ive checked since the plugs after swapping everything keep indicating the system is rich in fuel and i have even seen fuel misting towards the air filter housing when its running. The fuel solenoid appears to be functioning as i hear the audible click each time of the solenoid operation. Ive looked over the throttle and choke lines to inspect if anything was getting caught but operation is smooth.
Any input is greatly appreciated and if any more information is needed let me know i have a multimeter and can get readings more accurately if needed.
