How do you adjust that? I didn't know if there's a video out there on how to do that stuffYou would need to check the drive disc area. You'll probably need adjustments to where it hits in 1st gear and may need to adjust the contact pressure? Might need a new drive disc too? That's a good place to start.
Is the drive disc where it has like black rubber going around it?How do you adjust that? I didn't know if there's a video out there on how to do that stuff
