Nickster2213
- Mar 25, 2022
- 25
Where is the pilot adjust screw on Honda HR215HX?
It is running rich, I have taken the carburetor apart and cleaned it and replaced the spark plug and replaced air filter and checked the valve lash and combustion on piston is 85psiIf you look up your carb you will find there isn't a pilot adjusting screw. There is a low speed adjustment screw which is limited. What is your mower doing? Lots of expert advice here on the forum that will help you with your problem.
