- Nov 29, 2014
- Threads
- 64
- 24,729
Blade length is like TV or computer screen & measured diagonally from the tip of one cutting edge to the tip of the other side
I'm 74 and still learning!!.......I had NO idea..........sure enough.....21 and 3/16.........these blades were on this mower upside down when i bought it, the cutting edge never hit a blade of grass.........could be, that's why they sold it.......under the dust it was like new.........Blade length is like TV or computer screen & measured diagonally from the tip of one cutting edge to the tip of the other side
what startech posted above, is the most likely answer. If you look at the sticker on your link and my link, they show the same MTD number.That should be the "G" deck with two 21.25"/ 21-3/16" blades.
942-04308A Hi-lift
942-0616A Mulching
many thanks,,,,,,I'll let ya know if I got the right ones........what startech posted above, is the most likely answer. If you look at the sticker on your link and my link, they show the same MTD number.
It's been my experience that Oregon Durable blades are the best of all the aftermarket blades out there.Thanks a lot for your time bertsmobile1.......I'll try that road and see how i do........Jacks small engines was out of stock [If Idid the search right}....I'll try your other
places..........I have a kitty cat trying to help me with this....he just decided to la down on the keyboard....;=+++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++
I don't know who made Lawn Chief but sounds like it is 50+ years old! You can't even say Chief anymore!I bent a blade on my old lawn chief and thought that it would be an easy replace....but I can't seem to find the compatible blades anywhere....I can find what looks like it might work but none that i have seen seem to match up with the spindle hole shape??.....Will the star hole fit on my spindles???....the hole i have is NOT a star shape......I couldn't explain the shape..........the blades do have 6 point notched holes..... two
blade length and and two on each side of the blade... is there a universal i can use???.....the blades were on upside down when i bought this mower ...cutting edge never been used......that stump must have grown over the winter........any help will be appreciated ......
I'll probably get in trouble over this but..........I always say cats are a lot like women...if they want something; they figure a good way to get it.......I had to go and check my order......I was happy to find the right hole and length ......I only saw made in usa and bought them....oregon had done well with chain saw blades for me...in the last few years.......It's been my experience that Oregon Durable blades are the best of all the aftermarket blades out there.
