Engine swap, splicing into existing connector?
Also,
I believe this is the fuel shutoff solenoid, but have never seen in a side to side orientation...usually at the bottom of the float bowl vertically. I am going to cut off the plunger, but it looks different than the others I have seen?
That is the main jet anti back-fire solenoid all right.
Yellow wire is battery voltage.
Engine stopping is a ground.
2 red wires are both DC voltage.
jbmortensen
Why two red wires? Why not one? Are the two wires there to provide more current? Could I just hook up one of them?
