Working on a Cub Tank M60-KH, model 53BB5BDX750, ser. 0C295Z80032, 2005 model.
Cub Cadet and other websites that sell parts for the engine, call this engine a CV740S-0015. Unfortunately, the spec sticker on the motor is gone. Cub claims the motor on this model tank is a CV740S. That's all I have to go on.
One coil failed and the other one had weak spark, but the motor could be started and ran on one cylinder. By testing, I could see that the one coil pulsed every revolution.
Here's the problem: If this is a CV740S motor, all websites call for a Kohler coil 24 584 36S. I bought a set of coils to replace the original coils using the number 24 584 36S. Once installed, I removed the ground wire and turned the engine. No spark until I turned the key off, and then there was one good spark. Repeated tests did the same thing. At least the old coil sparked every revolution.
The original coils have a number of 25 584 15. If you do research on this coil, it's not made for this engine, but that's what has been on for years.
What's the difference between these coils? Can anybody help clear this confusion up? Thanks.
