TexasTinker'r
- May 23, 2023
- 2
Hello all, new to this forum but need some advice on my D160. It ran fine the last time I used it then this time after I started it, it was backfiring with puffs of black smoke coming out of the exhaust. I did a little research and thought it might be a ignition coil but after replacing both for $100 it still has the issue. I pulled the spark plugs and both were very black and sooty even though I just changed them when I did my spring service. I can only assume from here that it may be a carb issue but I am not sure and don't want to throw more bad money at it.
It is also a bit hard to start, I usually have to use ether to get it going and then after that it usually cranks up as long as it hasn't sat too long.
Engine is a B&S 44S977 type 0026G1
Any advice is welcome!!
