Collin Gurley
- Apr 29, 2023
- Threads
- 2
- 9
Hey guys so I recently got a Kubota t2380 riding mower for free and the previous owner said that it would run but wouldn't go forward. So I got it running after it had been sitting for a while and sure enough it does not go forward or backwards (stuck in neutral I believe), I checked the disengage lever and it was very loose like it was doing nothing. There was no spring attached and I attached a makeshift spring to see if that was the problem and it wasn't. So what do you guys think this could be? would low fluid cause the lever to be loose or will I have to take the axle out and crack it open to fix something inside? Thanks in advance
