MattG.inAZ
- Nov 13, 2021
- 7
Just amazing. I'm not sure I would have ever figured it out. I looked for an explanation in the text, but no go.Just download the owners and look through the parts list under the particular area you are need the parts for. Or go online to Searpartsdirect.com.
https://www.searspartsdirect.com/ma...man-917276030-front-engine-lawn-tractor-parts
Thought I had it. But no. I need the connector that is located in the front right tire in the pic. how do i find it?Just amazing. I'm not sure I would have ever figured it out. I looked for an explanation in the text, but no go.
thanks for the info. Onward and upward.
Excellent. I found a Kohler catalog which had this connector. We'll see. In meantime I'm going to order the male connector. The harness I got has a female connector and the original harness has a male. Go figure. Thanks for these part nums. I've got the tools for making connectors as I was restoring 1982 Honda 750s. Got the spades and all that stuff. Now I know it is Aptiv!Are you referring to this one?
If so normally it is only available as part of wiring harness. But it is available otherwise when you know that it is an Aptiv connector.
02984883 Male connector housing. Matching Female connector housing is 02973781.
View attachment 64514View attachment 64515
Now what gauge terminals do you need 16ga or 18ga? To install these you need the open barrel crimper. Here my open barrel had to be modified to install the male terminals.
