wellssc2002
I have a 2014 Craftsman that looks exactly like yours except red & black. I had lost the reverse because the pedal had sunk. Turns out the frame was broken completely through on both sides right in front of the rear wheels. The frame flexed/sagged making the pedal appear sunken. Looking online revealed this is a problem others have experienced in these models (I suspect the steel is too thin for yards with rougher terrain). I lined up the frame and welded it together. Then bridged the crack by bolting on 1/4" x 1 & 1/2" x 18" plates, and finally welding them in place. It was a fun "fix it" instead of a frustrating "fix it." Best of luck.
