be sure to check the other side in the same place to see if a crack has started there.I actually have a piece of 1/4 flat stock. My frame is 3” C channel so as per your instructions I will cut a 12” piece, once I take it apart I will know the width to cut it with my angle grinder with a diamond tipped blad!
Does that sound correct to you?
10-4be sure to check the other side in the same place to see if a crack has started there.
See if you can fit a 6" long 1/8x 1x1 piece of angle iron on it. Drill holes in the angle first, then Drill Frame and bolt, 1 hole at a time.Hi there, newbie here, we have a 2015 Husqvarna YTH 24- 48 I just found out why I’m getting scalping on the left side.the rear wheel The frame is broken not just cracked. Picture enclosed, has anyone seen this before and is there a fix besides welding?
!View attachment 64442
