17.5 (31C707-0154-e1) weak starter
boatdink
Replaced:
Starter
Cam
Tappet valves
Set the valve lash too
It's still acting like it's not decompressing. Could it be the Amazon starter being junk? I hooked the welder up to it and still didn't want to go. Bad ground?
Ocean909
Replaced:
Starter
Cam
Tappet valves
You can always try connecting power directly to the starter, bypassing the wiring and solenoid. If it goes you know you have a bad connection somewhere.
Also see how it cranks without a plug(s), no compression. It should crank at a good speed. If it doesn't may be a bad starter.
Why was all this replaced? was the old starter doing something similar? If so maybe other issue. Others will have a better idea I'm sure.
boatdink
You can always try conecting power directly to the starter, bypassing the wiring and solenoid. If it goes you know you have a bad connection somewhere.
Literally just tried it and no go.
If you tried to jump the starter by going directly + to starter and - to good chassis ground, and had no go, the starter is bad.
Which would put it on par with around 75% of the cheap "unbranded " starters sold on Amazon & Ebay
When will people understand
"If it is too cheap to be real then it is not real "
boatdink
I figured it out. I had the valves mixed up and did the wrong valve lash. Thanks everyone.
