Gas Tank
Sorry I’m not going to be a lot of help to you, as I’ve not sure how that tank is mounted. Many times you may need to loosen or remove the dash, which means pulling the steering shaft. If I was standing next to you, would probably figure it out in 5 minutes.
Thanks for the advice, it gives me a place to start.
