Electrical problem
Ifan
I having problem with my Hayter 13/30 not starting.
I’ve replaced the solenoid and the start switch. When the key is turned I get 15v at the solenoid (when the battery is connected to a charging pack), but the solenoid isn’t engaging. I have checked the grounding, and it seems to be ok. The solenoid is not faulty, as I have tested it. Why is there 15v coming into the solenoid, and out through the grounding, but it’s not engaging? Thanks
Try this to locate the problem.
Electrical problems can be very easy or very difficult, depending on four things.
1. How well you understand basic electricity.
2. What tools you have and know how to use.
3. How well you follow directions.
4. You don't overlook or assume anything and verify everything.
Remember we cannot see what you are doing. You are our eyes, ears and fingers in solving this problem. You must be as accurate as you can when you report back. The two basic tools we will ask you to use are a test light and a multi-meter. If you have an assistant when going through these tests it would be very helpful. These steps work the best when done in order, so please don't jump around. Now let's solve this problem.
First, check the fuse(s), check battery connections for corrosion (clean if necessary) and voltage - above 12.5 volts should be good. Check and make sure the chassis ground is clean and tight.
Second, check for power from the battery to one of the large terminals on the solenoid. One of the wires is connected directly to the battery and has power all the time so one of the large terminals should light a test light or show 12 volts on a meter at all times.
Third, check for power at the small terminal of the solenoid while depressing the clutch/brake pedal and holding the key in the start position (you may need an assistant to sit in the seat to override the safety switch). If your solenoid is a four wire solenoid, check both small wire terminals as one is ground and the other is power from the ignition switch. If your solenoid is a three wire solenoid, make sure the solenoid body is not corroded where it bolts to the chassis of the mower as this is your ground path back to the battery. If in doubt, remove the solenoid and clean the mounting area down to bare metal. If there is no power to the small terminal then your problem is most likely a safety switch, ignition switch or in the wiring.
Fourth, check for power on the other large terminal of the solenoid while holding the key in the start position (you may need an assistant to sit in the seat to override the safety switch).
Fifth, check for power at the starter while holding the key in the start position (assistant again).
Sixth, check your ground circuit back to the battery.
After you have gone through each of the above steps, let us know what happened when you did each step. At that point we will have great info to tell you how to proceed. Remember you are our eyes, ears, and fingers, so please be as accurate as possible.
Be as specific as possible with voltage readings as this will help diagnose your problem quicker. If you do not know how to perform the above checks, just ask and I will try to guide you through it. Youtube also has some videos and as you know a picture is worth a thousand words.
Okay here is a question. Where are you referring the ground return? At the battery or the frame? As these should be no voltage measured from the solenoid grounding point to the battery grounding point.
Here is your mower's wiring schematic.
At the frame near the solenoid grounding point, which is the key in my case, as I have changed the solenoid to a 4 post.
A 4 post starter solenoid doesn't ground through the base it needs one of the small terminals to be connected to ground to work.
I’m aware of this. The earth cable now runs from the 4th post to the ignition key, where it is earthed.
