happypilgrim
Hello, and thanks in advance for your help. For context, we are young/new homeowners and neither are mechanically inclined. We have been doing our best to learn as we go and have replaced blades, belts, and the battery on this mower since we purchased it second hand. However, we are far from being able to decipher parts diagrams easily and there's a lot of basic terms we don't understand whenever we try to read through trouble-shooting guides. I'd appreciate any clarity you guys can give me. We have an MTD mower, possible model numbers: 13AF673G000 or 13AF675G062 or 13BF675G062. We don't know the exact model number because when we bought it, the usual sticker under the seat was missing. Possibly built 04/24/02. To find parts list/maintenance/operators manuals, we go here and can find what seems to be the appropriate manuals under model number "13Af673g000".
The problem today: the mower won't start at all, we're not even getting a clicking sound or an engine-turnover sound when we turn the key. Voltage across the two battery terminals does measure 12+. This battery was new in 2020 and I don't think we've had issues with it since we installed it. This is the first attempt to start it for the season. Over the winter it was kept in a garage. The mower has gas, a fresh oil change, and the spark plug is fully attached. And the gas line is open.
The black battery post appears melted (see attached photos)? Could this be causing an inconsistent connection and thus preventing the motor from starting? I assume we need to replace the battery, but why would it have melted - e.g. what is the underlying problem, and I assume it would be something we would need to fix other than just replacing the battery? We did remove the battery today and the wires (red and black) that connect to it seem fine, don't seem to have breaks in their insulation, etc. At least, not until they run internally into the machine.
I believe the battery was purchased at Lowe's, in 2020. Brand, Magna Power, part no U1L-150. CCA@0 degrees: 150. CCA@ 37 degrees: 175.
Thanks much in advance!
