The Push mower
Cranks, starts and idles fine, but as soon as I release the brake the engine dies instantly. I checked seat safety switch which is normally closed-when no rider is on the mower and open when a rider is sitting on the mower. I am looking into the interlock switch now, but not 100% sure on how this one operates. Interlock switch black-to-black is closed (continuity) when brake is applied and the white-to-white acts the same. Should there be continuity between black-to-white at on any of the terminals? I am unable to find continuity at any point for any white-to-black connection when brake is applied or not applied on the interlock switch? If not, maybe I should be looking elsewhere for this electrical problem? Thanks for any help/suggestions in advance.
