Need help weed eater mower
1967
Hello, fixing this one. Has Briggs 12L9020667 in it. New carb, plug, filter, gas line and primer bulb. Only start with starter fluid, keeps running after. Don't start with primer bulb, replaced it twice. Carb is identical to hold one. About to give up on it. Thanks
Primer base gasket not sealing due the primer either warped or over tighten. Look at the gasket impression and add a wedge gasket to back of it in the area of none contact and retry.
Oh yea...must be one of those plastic carbs.
Nope, metal. Got new one, compared to old one and all is same. Previous post suggested that gasket was not sealing/ to tight; put new gasket on and get same results. Just a hobby I got to fix and sell but this one has me puzzle.
Sounds puzzling to me also...did you replace all of these components because it was doing the same symptoms it is now.
Got it not running at all. I flip them after fixing. All looks good so I don't know at this point.
