TroyC
 - Mar 3, 2023
- Threads
 - 1
 - 1
I have an OLD Troy-bilt Bronco and the engine finally died for good.  I replaced it with the Briggs and Stratton 19 hp that is currently installed in the newer Bronco.
Connected everything and started right up. Was cutting the yard and it suddenly shut down. And now will not crank at all. Any suggestions? Are there any fuses I can check?
