Looking for engine dimensions
upupandaway
Anyone have a link to a diagram of the dimensions of where the bolt holes are for a Briggs 281707?
I'm playing and would like to know where to drill holes vs eyeballing it.
TIA.
I looked there already. Mine is not there but there is a 14hp so I guess it should be the same. Thx.
Side valves & OHV engines have different bolt mounting patterns.
Singles & V twins have different bolt mounting patterns .
MTD , Murray , Noma ( others probably ) use a removable engine mounting plate
so if worse comes to worse you can get one of those from a mower wrecker
I might have one in the graveyard I will have a look latter today.
AFAIK all B&S ride on SV engines have the same mounting centres regardless of their stroke .
Apart from the crankshaft & oil seal housing the bottom is flat as it has to sit on a flat plate
So cut a 4" hole in the middle and you can use a corn flake packet to make a template .
